Browse Forums Heating, Cooling & Insulation Re: Adding a second Brivis Networker 12Jan 13, 2009 3:37 pm The second networkwer is normally the slave is useful when you have 2 zones .When heating second zone only ie Bedrooms second controller is usally in the master room so it can turn unit off when at rerquire temp.With a single controller in the middle of house it takes a lot longer for temp to travel from rooms to main area resulting in bedrooms running up to 5-6 degrees hotter than set point.
Speak to Brivis they should sent out paper work to wire Hi team, Im looking for a second hand sd4b monitor preferably white. 0 7310 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 24691 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 5817 |
