Eave Vents
Going to put in a solar roof vent and had was wondering whether under eave vents were really required.
I get the whole airflow thing but can I do without them? If the vent is set to maintain a roof temp of 20 degrees it will stop itself.
Also eave vents allow intake of cold air during winter which wouldn’t be a good thing as you’d want to keep your house warm.
Thoughts?
Eve vent are generally recommended as they help in maintaining airflow within roof.
they cannot be located above a window
if there is a fire the glass will break and the fire will go straight into the roof
It’s fully silent, can’t hear a thing. Does it work? Some days you can notice the difference upstairs but some days you can’t as heat still gets in via windows and other means. This is just the first step and hopefully I’ll be doing double glazing on my windows to help keep the heat out.
2
Old Home Restoration / Renovation
Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look…
25/03/2024
4
retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you…
