Browse Forums Heating, Cooling & Insulation Re: Air flow from the vent when the zone is OFF 10Mar 18, 2018 11:41 pm Just an observation - I noted that only two of the rooms have bad leaks the other rooms are pretty OK. I'm surprised the two rooms that are leaking badly are in different zones as well. One of the rooms (zone OFF) is like, 50% air flow as that of the room with zone ON. The other OFF room less than 20% air flow which I think is acceptable. Now, as I hear from Bels and sluggo, it's normal so I've to train my mind to accept it Re: Air flow from the vent when the zone is OFF 11Mar 18, 2018 11:57 pm voz I'm not sure where the other sensors are located? How do I check for normal reading? And how do I identify the right sensor for a given zone? Apologies, this is the first time I've a zoned air con. Appreciate your time again. Do you have sensors installed on walls elsewhere in your house? The rule of thumb is 1500 - 1650mm high. If you haven't got any installed then potentially they may not have installed them. By normal reading I mean looks like it is reading correctly (not 300 degrees or -263 degrees for example) hth Re: Air flow from the vent when the zone is OFF 12Mar 19, 2018 12:11 am No other wall installation just the controller. Should I ask them to install other sensors if they have missed it. They completed the install last week only. Not sure if it's common for them to install only one sensor but I would ask if you suggest. I'll simply try assigning other sensors to zones and see what the temperature is.. Re: Air flow from the vent when the zone is OFF 13Mar 19, 2018 12:40 am It really comes down to how much it annoys you and if it will benefit your installation. They are marked as optional though hence why they were probably not installed. You might be paying for the other sensors to be installed if it wasn't in the original scope. How beneficial they are really comes down to how your house is laid out, how the zones are split up and location of registers in each zone. With a single main return air intake, all the return air needs to flow back to that point. If there's factors which could affect the accurate measurement of the incoming return air such as solar load, then you'd definitely see a benefit to sensing across multiple zones and averaging the readings for control. hth Re: Air flow from the vent when the zone is OFF 14Mar 19, 2018 5:48 am Thanks mate I think it makes sense to leave it as-is with one sensor. Is main RC, main remote control sensor and sub RC sub remote control sensor? Meaning the sensors are in the remote control and senses based on wherever the remote control is? They didn't give me any remote control. Just the wifi app so if what I'm guessing is right, then those 2 sensors are not applicable in the first place. Also the other sensor is outdoor sensor. Why would someone assign it to any indoor zone in the first place? Trying to understand. Thanks so much! Re: Air flow from the vent when the zone is OFF 15Mar 19, 2018 1:03 pm Every manufacturer uses different terminology. Main RC is generally the sensor in the wallpad controller, sub RC is generally the coil sensor but don't quote me on that. Outside air sensors are generally for ambient lockout function or for economy control. Hth Re: Air flow from the vent when the zone is OFF 16Mar 19, 2018 7:54 pm Bels Every manufacturer uses different terminology. Main RC is generally the sensor in the wallpad controller, sub RC is generally the coil sensor but don't quote me on that. Outside air sensors are generally for ambient lockout function or for economy control. Hth Hi Bels, I did a temperature test as suggested, please see below observation. Zone 1 sensor set to the following - 1.) IC (Indoor Unit) = 29 degree C Note: IC sensor was the setting I had for all zones when the AC guys finished. Works well. 2.) Main RC = 30 degree C When I set the zone 1 sensor to Main RC, I get the following error on the controller display after a few mins. Error code - 5191 Error unit - IC Address - 001 3.) Sub RC = 8 degree C (8 blinking) 4.) Optional Sensor 1 = 8 degree C (8 blinking) 5.) Optional Sensor 2 = 8 degree C (8 blinking) With this, can we conclude whether additional sensors have been installed or not? It looks like the unit works based on only one sensor called 'IC' (Indoor Unit). Is it all good? or should I contact the air con company and ask about other sensors etc. Appreciate your time & help again. Re: Air flow from the vent when the zone is OFF 17Mar 19, 2018 8:50 pm 1. return air sensor 2. unsure of what this error is as it's not in my list of error codes. You may need to contact the installer if you need to find out what this is as I'm not sure of what your model of unit is. 3. likely not installed 4. Likely not installed 5. Likely not installed Re: Air flow from the vent when the zone is OFF 18Mar 19, 2018 9:10 pm Thanks Bels, With this setup, is it all good (or) should I ask for more sensors? I would assume this is the standard installation by the air con guys but would definitely have a chat about the sensors and confirm. And the model numbers below. Model no: PEA-RP140GAA Indoor unit PUHZ-RP140VKA2 Outdoor unit Re: Air flow from the vent when the zone is OFF 19Mar 19, 2018 11:23 pm There's nothing wrong with the method of control of your system. The air supplied to the active zones still returns through the common return air intake and sensed by the indoor unit sensor. That said if you were after more exact control then you'd want sensors in each zone. Now with averaging sensors, if a sensor is in a zone with a high solar load, it would raise the averaged temperature sensed and bring on greater cooling or in the example of heating the opposite. How do you feel your system is operating? Are the conditions comfortable in your house? Is there excessive or inadequate compressor on cycles? Do you feel there's room for improvement? Sometimes people chasing absolutes end up dissatisfied or unhappy with an otherwise well functioning system. A mentor long ago knocked it into my thick head that air conditioning is an inexact science. hth How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6983 You may still have a case, but your next step is to speak to a lawyer. 3 1618 |
