Browse Forums Heating, Cooling & Insulation 1 Aug 30, 2008 3:49 pm Hey Guys,
was looking into using colourbond for our new roof and i am keen to insulate the roof too, ive heard of using foil and now this ritek stuff :http://www.ritek.net.au/roof_faq.php i think its 2x sheets with foam inbetween anyone used it before? how does it compare up to the other products on the market? -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Roof Insulation - Foil/Foam/Ritek 2Sep 01, 2008 4:28 pm I'd say it's very expensive - two layers of Colorbond + EPS won't come cheap. I think that Ritek panels don't make sense unless you're considering a fancy skillion or profiled roof. For a normal stick or truss roof a layer of Anticon under the tin and the thick batts in the ceiling would be just as good as the panels, but most likely cheaper and simpler.
Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Roof Insulation - Foil/Foam/Ritek 3Sep 01, 2008 11:49 pm yeah i was a tad concerned when i found out it was 2x layers of colourbond!
whatabout the foil on the underside of the sheeting? every bit helps.. i am planning on having a small attic for my solar gear/wifi stuff; so thick insulation and boards will do. -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Roof Insulation - Foil/Foam/Ritek 4Sep 02, 2008 12:02 am Quote: whatabout the foil on the underside of the sheeting? every bit helps.. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Roof Insulation - Foil/Foam/Ritek 5Sep 02, 2008 1:36 am i didnt think about the sound deadening, fortunatly the boss likes the sound of the rain, i managed to find the building code of adelaide and theres alot of info in there regarding energy efficient roofing..
mm should have a look at this air-cell stuff thanks -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Roof Insulation - Foil/Foam/Ritek 6Nov 01, 2008 8:57 am FireFox Hey Guys, i am keen to insulate the roof too -Nathan Read this: http://forums.envirotalk.com.au/Insulat ... t7876.html I am in the same situation, would you be able to give some insights in to this? I am in SA 8 16956 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4108 It is in the manufactures installation guide, and AS 3727.1:2016 Section 5 Clause 5.4.3 p17 image p18 Figure 5.4.3 4 1549 |
