Browse Forums Heating, Cooling & Insulation 1 May 04, 2018 10:36 pm Hi there Looking for guidance for options to control temperature in wine room we are building. The wine room will be on our ground floor (not basement) between kitchen and dining and is quite small at 2m x 2.5m, with glass entry doors. It will need some kind of stability in temp so looking to see what options we have. Our builder has suggested a small split system air con just for the room. This seems to be the most economical option but the unit would be quite large on the wall and not quite the look we are going for. Any other options? thanks Re: Temp control for wine room 2May 04, 2018 11:50 pm What sort of wine will you be storing and are you concerned with humidity control? What temperature range are you looking to maintain? Have you considered a ceiling cassette split system? Can you build out a bulkhead and use a bulkhead split system? Re: Temp control for wine room 3May 05, 2018 8:03 am Thanks for your reply. We will be building our wine collection. Nothing extremely fancy, around up to no more than $150 per bottle, screw tops (no corks). Just looking for a steady temperature (I think 14-16 was recommended). Never heard of a ceiling cassette split system, will google that now. We could build out a bulkhead. Haven’t heard of bulkhead split so will google that too. Thanks. Re: Temp control for wine room 5May 05, 2018 9:54 pm What you require is borderline outside the envelop what a split system for air conditioning is designed for. You may be better off using a dedicated wine cellar cooler which is more medium temp refrigeration based. If you do decide to go with a split system for air conditioning, whether a high wall, ceiling cassette or bulkhead style, I'd suggest to only utilize on the lowest possible fan speed. Depending on what you clad the walls with, it would be best practice to install a vapor barrier behind to stop condensation issues which could cause mold issues To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 7397 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 4130 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 5341 |
