Evaporative cooling vs Split system
Page 1 of 2
We are stuck with the decision making for Evaporative cooling.
Many people suggest us its not worth it and people land up getting a split anyway. I have read reviews that it doesn't work above 30 degree temperature, there is always a wet feeling in the house and furniture.
Any suggestions anyone?? What is better- cost effective and usage wise?
Evap is great at night, you sleep beautifully, but on muggy days, yes you will get hot sweaty cooling that barely makes a difference, when it's 35 or so, also not great, on dry days, when it's 27-32,will work well.
Modern add on cooling is not real expensive to run, as it turns itself off when reaching your desired temperature and comes back on when the temperature starts to go up, it will work better, all the time in all temperatures, is much cooler.
We have solar with our house, so air con runs very cheaply, as when you use the aircon after work and in the day time on weekends, you use your own electricity.
Go with add on air conditioning, I've had both and for melbourne whether, it's air conditioning, all the way, no biast here, just experienced opinion.
If you don't ignore future trends, you will ignore evap air con.
- Energy-efficient heating as well as cooling (cheaper to operate than the gas system we had, at least with energy prices here in the ACT)
- Still works well on muggy days (in fact, refrigerative aircon works *really* well here by reducing the humidity as well as lowering the temperature, giving you double relief)
- Works across all temperature levels
- Doesn't give you that "wet" feeling that you can sometimes get with evap
- Not having to open windows to have it operate (especially at night, or when we're out, or when there's a lot of dust or pollen in the air)
- Works really well with rooftop solar generation
- Controls humidity levels, making it easier to quickly dry clothes and towels inside if needed, helping bathrooms dry out faster, reducing dust mite levels, and helping prevent mould growth (amongst other things)
- Evap can chew through a remarkable amount of water: we can generate our own electricity with solar panels, but we can't make our own water
In this house we've got reverse-cycle, in my previous house we had evap. In our new build we're having reverse-cycle. Key reasons:
Only issue with Canberra with reverse cycle is heating the heating effect is marginal on the very cold winter mornings. The units can spend more time defrosting than they do heating. Our struggles below about -5.
But cost wise I was very surprised at how 'cheap' our power bill for the winter quarter was. It was about $850, and that is heating a 200m2+ double story house. Downstairs during the day (and for a lot of the time during the day too as I wasn't working). In my old house we had gas heating and the winter bill was around $600 to heat a 110m2 house.
Our actron add on air con plus brevis 6 star ducted heating was 13, 900,this was done by a brilliant experienced installer using the highest quality and top notch design.
Joker, are you in Melb?
If so can you please message me your air con guy's details?
Type of house and geographical location usually determines the best approach
Melbourne generally fares better with evaporative
Both types have their advantage and disadvantages and asking one eyed individuals is not the best way to go
Melb has humid summers and evaporative is next to useless in the peak of summer, when you really need it.
One eyed? I have both evaporative and split air conds in the same house.
Does it sound like I'm avocating evaporative?
As I have both, I'm in a better position than most to suggest that refrigerated is better suited in Melbourne.
If one is not to express their opinion then why even have forums.
You believe that evaporative is better but haven't explained why. As you're entitled to your opinion, so am I.
Get it right the first time.
There are plenty of people who went for evaporative and have had to install split systems later.
Plenty of people also don’t understand how evap works and how to use them properly.
Me personally if I were in Melbourne and just wanted to add aircon (the assumption being i already had a decent heater) I would go evap without a second though.
If new house or I needed a heater too I would go reverse cycle but only because I would prefer just one system and the cost of heating with gas is getting stupid. Reverse cycle with solar etc starting to become the cheap option.
Where do you live?
Ever been in Melbourne on high 30s or 40 deg day?
Where do you live?
I live in Canberra and have lived in Melbourne. Again as I stated one big issue is people do not understand how evap works and how to use it properly. Sure doesn’t cool as well as refrigerative at higher outside temperatures but like everything in life there are trade off’s to be made. Evap when used properly will take the edge off those extra hot or humid days that which for many is good enough. Not everyone wants to be living in an igloo.
And I stated above these days in Canberra I have ducted reverse cycle in my new (18 month house). The trade off for me is the extra cost of running reverse cycle, but I went reverse cycle because new house, I didn’t want gas heating (so needed reverse cycle anyway) and have a double story house. So the logical choice.
But if I were to move back to Melbourne in an older house that had a good heater and no a/c I would not hesitate for one moment going evap.
Where do you live?
But if I were to move back to Melbourne in an older house that had a good heater and no a/c I would not hesitate for one moment going evap.[/quote]
What is it that you think those that have evaporative don't understand about how it works and what specifically are you saying they are doing wrong when using it?
[quote defaultattr=""] JB1 AJW
Where do you live?
Where do you live?
What is it that you think those that have evaporative don't understand about how it works and what specifically are you saying they are doing wrong when using it?[/quote]
I'd like to know also as I must be doing it all wrong because evaporative doesn't help my house when it's humid and 35deg.
1
Move your linen into laundry and access laundry from your present linen space
13/02/2024
2
Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271
25/06/2023
2
It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and…
