Opinion hydronic slab heating with engineered floorboards
I would be grateful on your opinion on my house build.
Double storey in Melbourne. Love hydronic heating. Slab for ground and radiators panels for top.
We love floorboards and want this on the ground floor, and now there is a lot of installers who are happy to support engineered floorboards as a covering.
Most internet experience I can find on hydronic slab heating relates to polish concrete or tiles covering, but not engineered floorboards.
Can I ask if anyone has any experience/thoughts on this - particularly the technology is much better, with even heat designed boards that conduct better?
If so, can anyone recommend floor board companies that sell good products in Melbourne?
Many thanks
MB
There are these new engineered boards where the base is made of stone and meant to conduct heat as close enough to tiles? and I wonder how they compare to other engineered boards that have wood on either side of the ply.
Thanks very much. How effective did you find the heating through wood in terms of keeping the house warm?
We're not there yet so I can’t comment. However, due to the insulative properties of timber, we have put the coils very close to the surface of the underlying slab. That said, our house design mostly keeps the house warm and the heating is just for any long sunless periods in winter.
That sounds like a very good idea. They will also add to the thermal mass of the floor.
Did you work out whether the cost to run per day would be cheaper than gas ducted heating ( excluding initial outlay costs?)
Gas is not an option for us in any form as we are building in a rural location.
Hi mboy, these stone based engineered boards sound intriguing. I googled them (heatboard) but couldn't find a price. Any idea how the cost compares to normal engineered boards?
Heatwood: reconstituted stone based with 3-4mm wood board lining : ~ $150 per m2 (240mm wide)
The other one is Mafi: you get wood on both sides with ply in the middle $170 per m2 (235mm wide).. I believe having wood on both sides makes everything 'more evenly' distributed and you get more wood!
Both products looks fantastic. You get a loss less wood with Mafi, but it make sense to have the poor conductive properties of wood kept to a minimum to be similar to tiles/polished concrete.
The limited experience I can find about hydronic slab heating with wood seems to be so variable, and I guess there are so many variables with the products and installation.
Unfortunately I cant find any personal experience to gauge which would be better.
Although hardwood is not the worst insulator, as long as it not very thick (e.g. below 15 mm) - it should be doing okay, as any insulator - just delaying the heat transfer, but once heated - it should be fine.
I think its not very common to do hydronic slab engineered board heating, and some builders have no experience in this.
They are more comfortable with panels or polished concrete/tile.
Thats another challenge!
Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator…
15/12/2023
Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am…
8/05/2023
3
Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is…
