Browse Forums Heating, Cooling & Insulation 1 Oct 08, 2017 2:06 pm Hi all I am building a double storey with Metricon in Melbourne and wanted to put Celing Fan in living and bedroom area. I was also thinking of having a couple of Split AC's for those hot days , in the Master bedroom and theatre. Looking to get answers and some suggestions on this topic and on the below points: 1. Can the Fan be put on the Baton light point ? 2. Is it a good idea to get the Fan and Split AC done by Builder or can be done later? 3. What provisions should I get done for those to be put at a later points. Thanks heaps Cheers Pal Re: Installing Fans and putting Split AC 2Oct 09, 2017 11:02 pm ilmessaggio Yes you can put a sweep fan on the light baton and you'll need 15amp supply run to the two anticipated future installation points. It might be better to advise the OP to check on the requirements based on the capacity he/she intends to install in said locations rather than just a blanket 15amp supply. Re: Installing Fans and putting Split AC 3Oct 12, 2017 2:26 pm pal_wollert Hi all I am building a double storey with Metricon in Melbourne and wanted to put Celing Fan in living and bedroom area. I was also thinking of having a couple of Split AC's for those hot days , in the Master bedroom and theatre. Looking to get answers and some suggestions on this topic and on the below points: 1. Can the Fan be put on the Baton light point ? 2. Is it a good idea to get the Fan and Split AC done by Builder or can be done later? 3. What provisions should I get done for those to be put at a later points. Thanks heaps Cheers Pal http://www.odyssey.com.au/odyssey-range/odyssey-hr2100 see more at hoffmangoldwithporterdavis.wordpress.com Re: Installing Fans and putting Split AC 4May 10, 2018 2:31 am pal_wollert Hi all I am building a double storey with Metricon in Melbourne and wanted to put Celing Fan in living and bedroom area. I was also thinking of having a couple of Split AC's for those hot days , in the Master bedroom and theatre. Looking to get answers and some suggestions on this topic and on the below points: 1. Can the Fan be put on the Baton light point ? 2. Is it a good idea to get the Fan and Split AC done by Builder or can be done later? 3. What provisions should I get done for those to be put at a later points. Thanks heaps Cheers Pal Iit’s definitely cheaper to use just your ceiling fan versus your mini split air conditioner. But we know that utilizing only a ceiling fan would still make it difficult to combat the heat and humidity. Before there ever was central air conditioning, ceiling fans were the tool for comfort. While we all know that ceiling fans circulate the air from the ceiling. While that air circulation doesn’t necessarily lower the temperature in the room, it works like a wind chill in that it can exploit the air temperature across your skin. As the air moves across your skin, it disperses your body heat, evaporating perspiration, thus making you feel cooler. Consider using a ceiling fan as part of a team to bring your maximum home cooling comfort. Adding a ceiling fan can allow you to actually turn up the thermostat, saving you energy and money. A way to conserve energy and cost is to make sure your ceiling fan is only on when the room is occupied. DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17318 Move your linen into laundry and access laundry from your present linen space 1 8007 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 |
