Browse Forums Heating, Cooling & Insulation 1 Sep 27, 2017 8:24 pm Hi guys, Just wanting a second opinion on installation of anticon. Our builder has accidentally put on our colourbond sheets without installing the anticon, and we were told that it is possible to remove the exisiting sheets and have the anticon installed (using the existing sheets). Any experts out there that could advise if this is going to work? I've spoken to the insulation guys - they seem to think that the only way to do it is to re-order new sheets as the existing ones will already have holes / prone to dents if reused. Re: Anticon Installation - after colourbond roof is installe 2Sep 28, 2017 10:24 pm Awesome, so its ok to reuse the sheets then! Thanks! Another question I have is, the ceilings are scheduled to go in tomorrow and i think the anticon will be installed sometime next week, this sequence is fine right? Sorry if the question sounds silly, i have no background in construction and its my first home so thank you in advance! Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8504 Yes i guess this is one of the main reason as i checked one post foundation 4 9994 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15787 |
