Browse Forums Heating, Cooling & Insulation 1 Apr 03, 2017 12:48 pm Re: Floor insulation supports. 3Apr 03, 2017 7:53 pm Hi Turbopsi You can have them easy break pressed up by a sheet metal fabrication shop Do it in one length..cut them down to size with a grinder youself Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Floor insulation supports. 5Apr 03, 2017 8:11 pm StructuralBIMGuy Hi Turbopsi You can have them easy break pressed up by a sheet metal fabrication shop Do it in one length..cut them down to size with a grinder youself Thanks for that. I was hoping they were available off the shelf. I haven't had to use a sheet metal fab shop before. Re: Floor insulation supports. 6Apr 03, 2017 8:15 pm I had the same concern but other manufacturers such as foilboard have similar plastic saddles for their product. http://www.foilboard-insulation.com.au/images/underfloortimberfloor.jpg 1 10129 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16553 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
