Browse Forums Heating, Cooling & Insulation 1 Jan 23, 2017 10:11 pm Thoughts on the photo? https://pbs.twimg.com/media/C22ruUOUUAA2Y_w.jpg:large Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Old House - Attic Insulation - Asbestos? 2Jan 23, 2017 10:31 pm Doesn't look like the loose-fill asbestos examples I've seen (looks more like cellulose), but that's not to say it couldn't be - the only way to be sure is to have it tested (generally a bit over $100 last time I checked, but free testing is available in some areas). What region is the house in? Re: Old House - Attic Insulation - Asbestos? 4Jan 23, 2017 10:48 pm Then geographically much more likely to be cellulose than asbestos - again, though, the only way to be 100% sure is to have it tested. Re: Old House - Attic Insulation - Asbestos? 5Jan 23, 2017 10:50 pm (oh, and make sure that you're using proper respiratory protection whenever you're up there - even if it's not asbestos, the flame retardants used in some of the cellulose products can also be pretty nasty) What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7274 4 1873 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8510 |
