Browse Forums Heating, Cooling & Insulation 1 Dec 21, 2016 7:21 pm Just bought a place and it came with this monstrosity: https://imgur.com/a/VgfrJ It's a gas / solar combo. Surely there is a better, neater way of doing this? Any ideas? Re: Ugly hot water unit replacement options? 3Dec 22, 2016 6:57 am Cheapest way would be to enclose it somehow, like a slatted fence with a gate opening. I can't post a link to pics for some reason but just google 'enclose hot water system' and 'images' and you'lll get the idea. My blog: tashandpaul.wordpress.com at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61372 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13675 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20226 |
