Browse Forums Heating, Cooling & Insulation 1 Aug 30, 2016 8:40 am I've got a problem with the aircon in my place. The condenser is outside (of course) and it is zoned inside. I didn't really know about it until someone slept in the second bedroom. When it turns on the condenser makes quite a bit of noise and also a "rattle" develops until it starts to really go. Then it seems to smooth out. But the initial rattle/hum is annoying. I can't remember it in previous aircons I have had. I found out that the unit should have been standing on "plastic legs" and got this done which helped with the problem a little. I've emailed Daikin who have not bothered to answer. Does anyone have a solution ? I feel it might just be a vibration type problem and thought of rubber mats etc. Re: Air Con - Excessive Noise at Start-up (Daikin) 2Aug 30, 2016 8:41 am I might add - the system heats and cools OK. Re: Air Con - Excessive Noise at Start-up (Daikin) 3Aug 30, 2016 10:06 am Write reply... Just found this - might give it go - https://www.youtube.com/watch?v=B0vw8DPPuwo It seems as if it might be a vibration thing - and it works good - so I hope its just that. Re: Air Con - Excessive Noise at Start-up (Daikin) 4Aug 30, 2016 10:52 am Clarke Rubber and Bunnings also have anti-vibration material. Will check it out. Re: Air Con - Excessive Noise at Start-up (Daikin) 6Sep 05, 2016 5:32 pm Well - I seem to have produced a solution. Fingers crossed. Noise seems to be gone. Re: Air Con - Excessive Noise at Start-up (Daikin) 7Sep 05, 2016 5:33 pm Bels That's just standard wafflepad available from Plumbing wholesalers that specialise in HVAC or Industrial. Re: Air Con - Excessive Noise at Start-up (Daikin) 8Sep 05, 2016 5:34 pm Write reply... Pity you couldn't have spoken up before - instead of after. Re: Air Con - Excessive Noise at Start-up (Daikin) 9Sep 05, 2016 8:32 pm Sorry about that, I didn't realise I needed to reply and offer a solution by a deadline... Unfortunately I don't get to pop on the forum nightly as I have young kids so sometimes they take up alot of my time. If you need a reply sooner feel free to PM next time. Re: Air Con - Excessive Noise at Start-up (Daikin) 10Sep 12, 2016 11:06 am Working well - so if anyone has the same problem it might be the answer. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
