Browse Forums Heating, Cooling & Insulation 1 Jun 23, 2016 12:20 am Hi, Assuming 45m2 of open living area and 9m2 of kitchen, how many ceiling fans should I get? Background: I live in Brisbane and love ceiling fans . So far I have found two different approaches to this problem: - bigger space = bigger ceiling fan - bigger space = more ceiling fans (http://www.yourhome.gov.au/passive-desi ... ve-cooling) At the moment I'm thinking to go with 4 ceiling fans (1 per 15m2). That would include one in the kitchen. Not sure whether that is a good idea. Looking for pros / cons of each approach. Thanks. Re: Ceiling fans - bigger or more? 2Jun 23, 2016 11:04 am When it comes to ceiling fans, bigger is always better and here's an article to support that claim - http://www.energyvanguard.com/blog-buil ... -Is-Better. It has a chart and some helpful insights on what ceiling fans to choose. As for your question, having more smaller ceiling fans means using more energy so that would lead to a larger electricity bill compared to using single or fewer bigger fans. Re: Ceiling fans - bigger or more? 3Jun 23, 2016 2:41 pm On the other hand, if you have four, you don't need to put them all on at once - just in the areas you're using at the time. Re: Ceiling fans - bigger or more? 4Jun 23, 2016 5:12 pm I would go one in lounge area. Not in the kitchen as they get greasy. Maybe one over the dining. I would go bigger. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 |
