Browse Forums Heating, Cooling & Insulation 1 May 12, 2016 6:13 pm Hello folks, My builder verbally mentioned that cost of referigerated cooling and heating will cost us $18k. Isn't this excessive?? Even with few zones it sounds bit of rip off. Can anyone comment on this please from your experience.. Thanks Re: Cost of refrigerated cooling and heating 2May 12, 2016 6:25 pm There is a sub forum called Heating, Cooling & Insulation. Probably a good idea to read the sticky below. viewtopic.php?f=1&t=75269 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cost of refrigerated cooling and heating 4May 12, 2016 11:23 pm Sounds high as I got brivis top of the range heating six star with 4 zones and 17 kw actron aircon 4 zones for 13900, this was the dearest quote but best Iinstaller with best materials used. Re: Cost of refrigerated cooling and heating 5May 13, 2016 9:21 am I got a 21kw actron add on unit and a breamar heater all installed for 12k. 4 zones. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: Cost of refrigerated cooling and heating 6May 13, 2016 6:38 pm Large builder that price seems fair. Would be a fairly large system Re: Cost of refrigerated cooling and heating 7May 15, 2016 9:11 pm thanks will check it out further to see what's on offer for such price.. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Cost of refrigerated cooling and heating 8May 15, 2016 10:02 pm I am using two Actron 17kw and its about 38K. 18K seems pretty good..... Re: Cost of refrigerated cooling and heating 9Jun 16, 2016 1:34 pm It may sound a bit expensive but I've seen much pricier refrigerated cooling and heating. My advise is to check out other available models/units near your location to make sure that you get your money's worth if your spending budget will be around that figure. Hi All, Our current 16 year old ducted gas heating is broken and needs an urgent replacement and appreciate any advise from the industry experts to make a decision for… 0 4001 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5521 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10603 |
