Browse Forums Heating, Cooling & Insulation 1 Jun 12, 2016 9:35 am I have just had a neo 1.6 freestanding heater installed. It won't burn overnight when fully flooded and airflow turned right down. The flue is straight and about 9 meters in length. I live on the side of a hill ( but nearer the bottom, almost valley like ). The top hat ( cowl ) is a normal one. Is there anything I can do to improve burns? Would a anti downdraft cowl be better or would it require a flue damper? Winds are not high at the moment. Re: Neo 1.6 combustion heater burning too quick. 2Jul 08, 2016 4:06 pm Hi, these pacific energy wood heaters feature what they call "ebt2" http://www.pacificenergy.net/technologies/wood/ebt2/ Even with the lever set all the way down it will self regulate the amount of air it needs. More info here: https://www.chimneysweeponline.com/hoebt.htm Might be worth while checking the ebt2 mechanism is operational and not stuck. Re: Neo 1.6 combustion heater burning too quick. 3Jul 08, 2016 5:23 pm This website is also great recourse in regards to PE wood heaters. Here's one example that may help you. http://www.hearth.com/talk/threads/paci ... st-2056552 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 5226 0 671 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 5274 |
