Hello folks,
My builder verbally mentioned that cost of referigerated cooling and heating will cost us $18k. Isn't this excessive?? Even with few zones it sounds bit of rip off. Can anyone comment on this please from your experience..
Thanks
Browse Forums Heating, Cooling & Insulation 1 May 12, 2016 6:13 pm Hello folks, My builder verbally mentioned that cost of referigerated cooling and heating will cost us $18k. Isn't this excessive?? Even with few zones it sounds bit of rip off. Can anyone comment on this please from your experience.. Thanks Re: Cost of refrigerated cooling and heating 2May 12, 2016 6:25 pm There is a sub forum called Heating, Cooling & Insulation. Probably a good idea to read the sticky below. viewtopic.php?f=1&t=75269 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cost of refrigerated cooling and heating 4May 12, 2016 11:23 pm Sounds high as I got brivis top of the range heating six star with 4 zones and 17 kw actron aircon 4 zones for 13900, this was the dearest quote but best Iinstaller with best materials used. Re: Cost of refrigerated cooling and heating 5May 13, 2016 9:21 am I got a 21kw actron add on unit and a breamar heater all installed for 12k. 4 zones. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: Cost of refrigerated cooling and heating 6May 13, 2016 6:38 pm Large builder that price seems fair. Would be a fairly large system Re: Cost of refrigerated cooling and heating 7May 15, 2016 9:11 pm thanks will check it out further to see what's on offer for such price.. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Cost of refrigerated cooling and heating 8May 15, 2016 10:02 pm I am using two Actron 17kw and its about 38K. 18K seems pretty good..... Re: Cost of refrigerated cooling and heating 9Jun 16, 2016 1:34 pm It may sound a bit expensive but I've seen much pricier refrigerated cooling and heating. My advise is to check out other available models/units near your location to make sure that you get your money's worth if your spending budget will be around that figure. Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5334 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10480 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 8245 |
