Browse Forums Heating, Cooling & Insulation 1 Feb 12, 2016 4:52 pm were going to go with porter davis to install quote 16,500. not sure what system this is yet. private air con company tells me no way will one unit do one house and quoted 28k. has anyone got porter davis to install (or any other builder) in this size house, how does it work and what system do you have?? last thing i need is to pay that much and get a system that wont keep the house cool! Re: refridgerated cooling in porter davis waldorf 48 mixed i 2Feb 12, 2016 8:34 pm One thing to consider is how much of the house you need too keep cool on hot days. If the house is well designed to close off excess rooms, and still maintain return-air circulation, you can get by with a smaller unit than if you try to cool the whole house. You have to also ask yourself if you really want to be going through the amount of electricity that would be needed to run greater cooling capacity than one large system. Another option is to spend the money on better energy efficiency, such as in double-glazed windows, and ensuring summer sunshine is externally shaded. You could also consider having one ducted system, and also an extra one or two split system units. There's a lot of different ways you can use the flexibility of that to your advantage. A split can give individual temperature regulation, and has no need to keep doors open for the return air flow. Then you can have one or the other on, or both to get maximum capacity. Re: refridgerated cooling in porter davis waldorf 48 mixed i 3Feb 13, 2016 12:11 am If you want a sensible answer, ring Executive Heat and Cooling in Hallam, and speak to Shane - he's the guy who does the heating/cooling design and quoting for Porter Davis builds... friendly guy with a lot of good information to share
Remember also, that nearly all AC operates optimally when you are trying to bring the temperature inside the house to about 10 degrees below the ambient temperature. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Wow that is terrible about the insurance! I guess ideally proof of insurance should be provided prior to first deposit but I'd imagine they would refuse to be out of… 17 14236 There isn't any need to. As I wrote previously, there isn't a set term, there is just commencement based on earlier of contract signing or building permit issue and… 24 13391 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 6495 |
