Browse Forums Heating, Cooling & Insulation 1 Dec 28, 2015 9:55 pm So today was a scorcher in Perth (41 deg). and we are building a new home in Ellenbrook. Our new home will have a 12.5 BAL (bush attack level rating) so I wanted to ask what aircons are we allowed to get. I don't really like split systems and I'm hoping we can get at least an evap. Our home is a 3X2 with a theatre and study. Does anyone know the costs of an evap if we are allowed it? Our Easystart Build in Annie's Landing https://forum.homeone.com.au/viewtopic.php?f=31&t=81061&p=1478674#p1478674 Re: Aircon choices for 12.5 BAL (bush attack level) house? 3Dec 29, 2015 7:04 pm Evaps are allowed but they require a mesh screen to be fitted to comply with BAL ratings. I'm personally not a fan as they are useless once it gets much hotter than 30 degrees My build with FHBD viewtopic.php?f=31&t=78344 Re: Aircon choices for 12.5 BAL (bush attack level) house? 4Dec 29, 2015 7:34 pm Might be personal preference, I've lived in many homes with evap and pretty much only used them when it was over 30 degree temps and they were great. Only struggle on humid days which aren't that many in Perth Re: Aircon choices for 12.5 BAL (bush attack level) house? 5Dec 29, 2015 8:01 pm Daz_ Evaps are allowed but they require a mesh screen to be fitted to comply with BAL ratings. I'm personally not a fan as they are useless once it gets much hotter than 30 degrees That is not correct. The Bonair employ an enviroseal automatic flap in the throat of the riser tower which makes it compliant. The mesh isn't required with the enviroseal. Re: Aircon choices for 12.5 BAL (bush attack level) house? 6Dec 29, 2015 8:56 pm My house is in a BAL 29 Area. I have evap cooling and have stainless steel embers screens fitted to comply with BAL 29 requirements. I am in an inland location with typically very low summer humidity. On a 37 degree day the evap cooler pulls the air inside the house down to 23 degrees. Re: Aircon choices for 12.5 BAL (bush attack level) house? 7Dec 30, 2015 7:50 am "The Building Code of Australia (BCA) prescribes the mandatory use of AS 3959: 2009 as the means of demonstrating building compliance in BAL 12.5 to BAL 29 level areas. Requirements for evaporative coolers for installation into all residential applications (Class 1, 2, 3 and 10a buildings) in these BAL areas are as follows: Clause 5.6.5 (f) Evaporative cooling units shall be fitted with non-combustible butterfly closers as close as practicable to the roof level or the unit shall be fitted with non-combustible covers with a mesh or perforated sheet with a maximum aperture of 2mm, made of corrosion resistant steel, bronze or aluminium." This is what I relied on re the enviroseal on my unit. The seal is required or the mesh is required. You could have both if you wanted but requirements are one or the other. Re: Aircon choices for 12.5 BAL (bush attack level) house? 8Dec 30, 2015 12:13 pm Thanks guys. It's all so technical. I'm a female and I just want to click a button and I have cool air. Hahaha. I might look more into in when we are ready to move in so many decisions. Our Easystart Build in Annie's Landing https://forum.homeone.com.au/viewtopic.php?f=31&t=81061&p=1478674#p1478674 Re: Aircon choices for 12.5 BAL (bush attack level) house? 9Dec 31, 2015 3:35 pm Re: Aircon choices for 12.5 BAL (bush attack level) house? 10Dec 31, 2015 3:45 pm Decka Might find this of help, from the breezeair catalogue online http://i1168.photobucket.com/albums/r483/decka2/Breezair_zpscc3bl7kj.jpg Thanks Decka ? Our Easystart Build in Annie's Landing https://forum.homeone.com.au/viewtopic.php?f=31&t=81061&p=1478674#p1478674 Re: Aircon choices for 12.5 BAL (bush attack level) house? 11Dec 31, 2015 8:55 pm Hey CM is there a specific reason why you want to go for Evap ? Given that you are in Ellenbrook I will not recommend getting one. A friend have it installed and as daz mentioned they don't cut it. Re: Aircon choices for 12.5 BAL (bush attack level) house? 12Dec 31, 2015 8:57 pm No specific reason. It's what we have now in our rental and it does the job even though many people don't like it. I guess I'd like something that's not going to eat at electricity too. Our Easystart Build in Annie's Landing https://forum.homeone.com.au/viewtopic.php?f=31&t=81061&p=1478674#p1478674 Re: Aircon choices for 12.5 BAL (bush attack level) house? 13Jan 02, 2016 9:28 am ChantalMaree No specific reason. It's what we have now in our rental and it does the job even though many people don't like it. I guess I'd like something that's not going to eat at electricity too. Ensure you have a well insulated home, and you'll probably find that a split system a/c won't cost you an arm and a leg to run. An evaporative unit works great in places like Melbourne and Adelaide (and other places with low humidity in summer), but the further north you go on the East Coast, the less efficient they become. Edit: just looked after I replied, you are on the West Coast. But still look at average humidity levels during the summer for your location... the higher the average humidity levels, the less efficient evap is. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . 3 4167 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
