Browse Forums Heating, Cooling & Insulation 1 Oct 05, 2015 10:05 am Hi all I have just finished building a new home and moved in a couple of weeks ago. Now the weather has heated up. I used the Evap cooling and I am constant vacuuming and sweeping up hundreds upon hundreds of small fly things...! What can I do to fix this? Is it the building companies responsibility or mine now? Tia Re: Evap Cooling and bugs 2Oct 19, 2015 9:22 am Hi Tia I know one of my friend had the similar issue and the fix he did was ask the evap guys to come back and clean it plus add a mesh around it to stop small insect coming in. This fixed the issue for him so far no problems They done the evap installation after handover. regards I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10040 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6178 Hi there, We've just build a new hardwood (Greybox) deck and am wondering whether firepit protective mats/surfaces are sufficient? I'm not sure that they're heat… 0 2116 |
