Browse Forums Heating, Cooling & Insulation Re: Ducted Aircon Brisbane 2Jul 09, 2015 12:38 pm Depending on where in Brisbane, but I'm on the Gold Coast and used a company down this way called design air. Pretty sure they would travel that way. Give them a call, was the cheapest and one of the better places that we spoke to. Not many people would email back anyway. They made up a nice design and quote package. Re: Ducted Aircon Brisbane 4Jul 10, 2015 12:25 pm No worries, if you decide to go ahead with them, can you let them know I referred you Re: Ducted Aircon Brisbane 6Jul 23, 2015 4:30 pm Oh that's not good then. Did you find someone cheaper? They were the around the cheapest that I could find. Re: Ducted Aircon Brisbane 7Jul 27, 2015 7:54 pm We used Proudlock Airconditiong for ours they came in way under what our builder quoted us so perhaps they could help you. My build viewtopic.php?t=76386 Re: Ducted Aircon Brisbane 8Jul 29, 2015 8:48 am Spent awhile doing research myself when I was getting my ducted installed. So here's my short list: - Airforce Pty Ltd (based out of Eaton's Hill). Small group, but very helpful and they knew their stuff. They did advise though straight out that they only install "expensive" systems. They use inidividual controllers for each zone, they were about 3-4 thousand more expensive then a "normal" system. - Acer Services. Was going to go with these guys. Prices were good, they use MHIAA. Only issue was lack of communication which is why I gave up on them. - Airmark Airconditioning. Fairly cheap, not the cheapest but still competitive. A bit unresponsive to initial requests (I was emailing, better to call). I went with these guys and got a Toshiba 12.5kw system + Daikin 3.5kw P series split, along with two new circuits the total cost was around $12000. The install was pretty good. Systems are running today with no issues, so they get a recommendation from me. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: Ducted Aircon Brisbane 9Aug 02, 2015 9:06 pm Take it or leave it, but my advice would be if a good quality well designed ducted AC system is out of your budget, then a cheap as chips poorly designed system will definitely be out of your long term budget because it will be expensive to run and will probably end up being a lifetime maintenance headache. And if it's an unknown Chinese brand of system, good luck finding spare parts for it in 5-10 years when the compressor dies or PCB fries itself or something. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15883 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 15478 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
