Browse Forums Heating, Cooling & Insulation Re: Ducted Aircon Brisbane 9Aug 02, 2015 10:06 pm Take it or leave it, but my advice would be if a good quality well designed ducted AC system is out of your budget, then a cheap as chips poorly designed system will definitely be out of your long term budget because it will be expensive to run and will probably end up being a lifetime maintenance headache. And if it's an unknown Chinese brand of system, good luck finding spare parts for it in 5-10 years when the compressor dies or PCB fries itself or something. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 12545 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 995 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
