Browse Forums Heating, Cooling & Insulation 1 Jul 08, 2015 4:40 pm hi Mistral air con is installed in my house, it was installed before i brought the house. this is info about the air con: http://i.imgur.com/MAwwtgs.jpg this is reverse air con and no warranty on this one as mistral have closed its Australian operations. this is pic of the remote: http://i.imgur.com/lCEq7BO.jpg if i press the operation mode button on the remote, following things happen: 1. In one operation mode, air comes out from the inside unit runs without any air conditioning. outside compressor and fan do not run. 2. In other operation mode, Outside compressor and fan runs without any air coming out from inside unit. i could not any find user manual for this model. Coils in outside unit r quite dirty, i have seen youtube videos of cleaning them with water. Should i do that? any suggestions to get this working? thanks Re: Mistral Split ac unit help 2Jul 09, 2015 11:28 pm Jatt809 1. In one operation mode, air comes out from the inside unit runs without any air conditioning. outside compressor and fan do not run. Which mode exactly? Quote: 2. In other operation mode, Outside compressor and fan runs without any air coming out from inside unit. Again which modes are you referring to? Quote: Coils in outside unit r quite dirty, i have seen youtube videos of cleaning them with water. Should i do that? I would highly suggest to steer clear of this unless you know what you are doing as getting water into where you shouldn't could lead to fire, equipment damage and injury or death from electric shock. I'm in no way suggesting this will happen to you but the potential for it to happen is greater vs someone who knows what they are doing, to do it. Quote: any suggestions to get this working? thanks Maybe get a refrigeration mechanic out to look at it hth Move your linen into laundry and access laundry from your present linen space 1 8007 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36936 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7930 |
