Browse Forums Heating, Cooling & Insulation 1 Jul 03, 2015 2:29 pm We are building a house with Blueprint who was offering a ducted air conditioning as part of the plan. The AC guys suggest a 12.5kw premium inverter Panasonic system. They insist its enough for the house but they suggested upgrading the ducts insulation to R1.5 and R1.2 to bendy ducts as they are more flexible given that I will choose a darker colorbond colour. I also have 31c ceilings throughout. Do you think this is gonna be enough? Also is R1.5 really not that flexible? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with ducted AC sizing 2Aug 22, 2015 8:59 am This calculator can figure out how many kw of cooling power you need for each room: http://fairair.com.au/Calculator.Size.aspx Re: Help with ducted AC sizing 4Aug 24, 2015 10:05 am Based on what we have, and assuming Perth climate to be similar to Adelaide it should be adequate, particularly with the better duct insulation. However, if I recall correctly, the minimum power of the 12.5kW is the same as the minimum power of the 14kW unit, at 3.3kW, so you don't lose out in going to the bigger one. For a given power output, the larger one should also run slightly more efficiently. Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6405 |
