Browse Forums Heating, Cooling & Insulation 1 Feb 10, 2015 8:14 am Not sure if this is in the correct category, but we have been having problems with our chromogen solar got water system. Its the chromogen SV 30 Basically last few days the hot water is just warm and the pressure of the water although usable has gone right down. Would this be a hot water problem or a plumbing issue? Mind you the house is newly built so I will give the builders a ring. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14028 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
