Browse Forums Heating, Cooling & Insulation 1 Jan 18, 2015 6:50 pm As the tittle said My daikin ducted unit rq140lav Sometimes the green light on the wall pad turns on but no air nothing unless I turn it off on the breaker for 30 minutes only happens on hot days above 30 degrees Other problem is supply air temp is 22.8 degrees which I think is way to high Unit is around 11 12 months old Thanks Re: Long shot does any one here work as a daikin air con tec 2Jan 19, 2015 4:14 pm If its only 11 months old then surely its still under warranty and you can get them to come and check it out for free? That's what i'd be requesting of them. I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36934 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
