Browse Forums Heating, Cooling & Insulation 1 Jan 01, 2015 11:50 am Hello. I'm converting a metal garage into a studio that needs to be reasonably cool in Qld summer. I have no delusions that I won't need aircon as well, but would like to achieve as much as possible with just insulation. A general search for info has lead me to the conclusion that both sarking and insulation batts are recommended. I'll be installing plasterboard for internal walls, so I've battened with timber attached to the steel frame, which leaves clearance of about three or four inches from the external metal sheeting to the inside edge of the battens. QUESTION: Which option is recommended: A) Install the sarking first (ensuring a gap between external sheeting and sarking), then sandwich the insulation batts between the sarking and the plasterboard; or... B) Install batts first, then install sarking between batts and plasterboard? If B) is viable, do I still need to leave a gap between batts and sarking? Building Standards; Getting It Right! Hi all Iām in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 12626 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11326 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6269 |
