Browse Forums Heating, Cooling & Insulation 1 Dec 13, 2014 1:04 pm By default, my builder has assigned my airconditioning outside my master bedroom. However, I'm a light sleeper and would prefer the external a/c unit to be placed somewhere else. Unfortunately, the only place i have in mind is somewhat close to my Instant Gas HWU. What are the regulations as to minimum clearance between the aircon system I will be installing my a/c system after turn key but would need the weatherproof GPO to be installed by the builder beforehand. I've called several a/c installers (4 in memory) and answers range from 500mm to 2.5m ! I'm located in WA by the way and looking at a reverse cycle ducted system (heating and cooling). Re: Air cond and HWU clearance 3Dec 22, 2014 5:53 pm We were told that aircon unit had to be 500mm from the corner of a house (not sure why - access I guess) and at least 500mm from an opening window. In our townhouse, the aircon unit would be about 1m from the Gas HWU (and we're in Perth). Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1892 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5899 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
