Browse Forums Heating, Cooling & Insulation 1 Dec 06, 2014 5:52 pm HI Everyone. Just building a new home and in their upgrades package are including a ducted air conditioner. Im just worried its severely undersized for the home. As part of the package also was an extra 2 squares on the home and we have also upgraded ceiling height to 2.7metres. I'm assuming they have not taken all of this into account and are under supplying me. Details of house all up 27 Square home colourbond roof with anticon blanket and insulation walls and ceiling excluding garage. 2700 high ceilings. Actron SRA 153C 14.7KW ( net ) ducted supplied What would most people suggest for this house. Building the Sheffield 25 + 2 sq Re: What Kw ducting Air Con?? 2Dec 12, 2014 12:58 pm Does the 250sqm include garage? If so they it's probably more about 200sqm~. Its a 16kw unit for comparison sake and looks to be an older model (3phase). Total Capacity - Cooling / Heating 15.27kw / 14.45kw 16kw will work fine for 200sqm~. However as mentioned, it appears to be an older model. Possibly ask for a price for one of the new ESP Plus range and compare. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: What Kw ducting Air Con?? 3Dec 15, 2014 5:16 pm We have a 18 kw 3 phase unit with a 24sq area house not inc garage. it is zoned living and bedrooms, with 1 zone open on a 40 deg day works fantastic with 2 zones open works ok. 1 zone will hold temp around 21-23 two zones open temp is around 23-25. hope this helps How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
