Browse Forums Heating, Cooling & Insulation 1 Sep 28, 2014 2:15 pm Hi H1, I'm after some suggestions on how to heat and cool a new area from an extension we are about to start on. Our current house (https://www.flickr.com/photos/jesscar/12111458053/ ) has ducted evaporative cooling, a 40yo old gas wall furnace in the front room and basic old insulation (not sure what R rating it would be). We are in Perth so the inside of our house can get up to around 33 and down to around 12 with no heating/cooling turned on. We are getting a flat roof extension adding 50sqm and turning one of our current living areas (with 1 evap duct) into an open plan area with another room attached (plan here https://www.flickr.com/photos/jesscar/15219812561/). The walls will be approx R2.5 and roof I think R3.5 with an anticon layer. Due to the flat roof adding more ducts is not an option. So, what would people recommend for heating and cooling this new space? I was originally thinking ceiling fans with a gas log fire, but they turned out to be $7k-9k so I was thinking perhaps one large split system might be better. I'm after the most economical option when you factor in ongoing costs as well as initial cost. WDYT? CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8478 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5461 |
