Browse Forums Heating, Cooling & Insulation 1 Jun 01, 2008 4:41 am I find them really ugly. Can the return air be hidden like inside the Walk-in-Linen or something?
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ \/\/\/\/\/\/\/\/\/ Re: Return air grill 2Jun 01, 2008 8:12 am Not only ugly, but they get dirty and are the air flow is noisy.
To help answer your question I think the reason they have them in an open area is the thermostat is located in the vicinity to measure the ambient temperature of the air going into it. Re: Return air grill 3Jun 01, 2008 7:30 pm Return air grilles must be located in an area that is being heated can not be installed where air can been drawn by a unheated area.
You can get different types of return air grilles i find timber ones look good because you can paint them the colour you want. By the way thermostat should'nt be located above the return either people put them there because it's easy to get the cable there. Thermostats should be installed at 1500mm and in the main living area has nothing to do with return air. Re: Return air grill 4Jun 04, 2008 7:35 pm I see. So that's the use of the return air. Hmm... not sure yet where we'll place this in out home but i want to try to hide it as much as possible.
Thanks Kiwi and Brad. \/\/\/\/\/\/\/\/\/ How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
