Browse Forums Heating, Cooling & Insulation Re: Hot water system - normal operating sound? 4Jun 25, 2014 7:52 am Brannor Thanks. Just concerned as that noise started 10+ months after it was installed. So it hasn't always made that noise. -G If its 12 month warranty that sounds about right ... I remember in one house (older) we could never hear the shower or hot water in other rooms. In the newer places you seem to get the noise more. Is this due to less insulation etc ? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14212 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2676 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20352 |
