Browse Forums Heating, Cooling & Insulation 1 May 05, 2014 10:42 pm I am looking at purchasing a 12.5kw ducted inverter air con. At first I was considering a Panasonic unit, which has an EER and COP rating of 3.21 and 3.37 respectively. Then I started looking at the equivalent 12.5kw Mitsubishi, which confusingly has an EER rating and two different AEER ratings, and a COP rating and ACOP rating. I am in Melbourne and plan to use the unit for heating more so than cooling. The COP/ACOP ratings are variously 3.98 to 4.28, which is significantly higher than the Panasonic and in fact greater than most other ducted air cons on the market (as far as I can tell). Would this make the Mitsubishi far more efficient to run (for heating) than the Panasonic? Is there anything I'm missing, and what to make of the confusing EER/AEER and COP/ACOP ratings? Links to specs: Panasonic - http://www.panasonic.com/au/consumer/ai ... pe1r5.html Mitsubishi - http://www.mitsubishielectric.com.au/Mi ... ucted.html How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
