Browse Forums Heating, Cooling & Insulation 1 Apr 15, 2014 9:11 am Hi Guys, I have Nobo Heating Wall panels installed throughout my house. Most of them have their own thermostat and timers which I s good but there are two slimline panels that I have mounted in batherooms under a floating vanity that don't come with timers or thermostats in this model size. Here is the panel that I am trying to install thermo and timer for: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://www.appliancesdirectonline.com.a ... e2e12.html And here is the DEVIreg Touch Thermo that I would like to use to control only the on/off of panel when reaching temperature and also to set on/off on timer. I understand I wont be able to adjust the temperature of the heating panel through this thermo but it will be okay if I just set the panel to around 21degrees. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://www.devexsystems.com.au/persiste ... nguide.pdf Question for your sparkies/heating contractors is that is it possible to install this DEVIreg touch thermo that will work with these heating panels? Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3074 0 10945 Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what… 0 1684 |
