Browse Forums Heating, Cooling & Insulation Re: reflective foil wall wrap around 2Apr 08, 2014 7:16 pm There is some information at this link abut the difference the reflective sarking makes: http://www.anewhouse.com.au/2012/02/ins ... -finishes/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: reflective foil wall wrap around 4Apr 09, 2014 6:01 pm gav89z Hi all, we are owner building double storey home, is reflective foil wall wrap recommended? As we will be installing wall bats. Many thanks, With a brick veneer construction the foil is necessary plus you gain insulation value. With a weatherboard type construction there is no addition R value as there is no cavity. In some situations there may be a requirement to meet bushfire regulations - depending upon the cladding & the situation. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17052 Vapour permeable wraps are recommended for any climate and main think it is allow walls to breath (i.e. remove water vapour) while at the same time, providing protection… 4 9781 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11273 |
