Browse Forums Heating, Cooling & Insulation 1 Feb 20, 2014 9:44 am Hi Guys, Any help will be greatly appreciated. We have signed final contract with our builder with heating taken out in the view of getting reverse cycle ducted system after handover. They are happy to provide powerpoints or anything else needed for the system. We preferably want ACTRON ESP+ 18KW single phase system. Does anyone know what is prerequisite? Like location of powerpoints? how may? any other specs? I have been contacting dealers, unfortunately they have been really cold to respond, I think its because its not going to be immediate job, its something after 6-7 months. Thanks Re: ACTRON ESP+ Prerequirsites from builder 2Feb 20, 2014 10:02 am I gather you mean either the SRD 191C or the SRV191E. Looking at the specs it seems it requires one powerpoint outside which would be next to where the unit was going to be placed, and one powerpoint next to where the fan unit will be in the roof. The outside circuit be would be a standalone circuit. If you have doubts why not ring Actron. I am sure they could give you all the information you require. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: ACTRON ESP+ Prerequirsites from builder 3Feb 20, 2014 10:07 am Single storey house? The power points required for this unit will be quite large. There are electrical standards to adhere to in terms of sizing the cable and how they terminate it. Generally you don't need to provide anything to the aircon installers as they will run their own circuit on the board and wire it back to the indoor/outdoor units. The only thing you should do is provide 3Phase power... makes for less stress. Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: ACTRON ESP+ Prerequirsites from builder 4Feb 20, 2014 10:34 am Its a double storey house. Its this house and has a bit of void in it. http://www.urbanedgehomes.com.au/pdf/fl ... orplan.pdf As far as power goes I think I just read specs, it says Power Supply (V / Ph / Hz) Outdoor 230V / 1Ph + N / 50Hz Indoor 230V / 1Ph + N / 50Hz So, I think I am sorted out half way. Any views if single phase unit will be enough? Do you think we can place outdoor unit on either side of house? Re: ACTRON ESP+ Prerequirsites from builder 5Feb 20, 2014 11:13 am I would be getting the builder to run the ducts then. You won't be able to get the ducting through once the house is complete. I think you need to start getting quotes from installers. Understand where they are looking to put the units and then just get the builder to put an isolator, it's easier for the installer to connect to that than the DB board. DON'T FORGET THE RETURN AIR !!!!!!! Get it designed into the plans or you may have an unsightly grill in your ceiling! Re: ACTRON ESP+ Prerequirsites from builder 6Feb 20, 2014 11:23 am Crazyk I would be getting the builder to run the ducts then. You won't be able to get the ducting through once the house is complete. Why not? Yeah its definitely easier to do it pre linings but not impossible to put in ducts at any stage. Re: ACTRON ESP+ Prerequirsites from builder 7Feb 20, 2014 11:32 am If you have solid floor truss then it will be impossible to run the ducts. On the other hand, I'm not sure I can see how you are going to run ducts after handover to all those rooms in only 300mm ceiling cavity that is fully lined. The duct alone will be close to 300mm. You may prove me wrong, but even with the steel web truss it's a squeeze getting them through. Cheers Re: ACTRON ESP+ Prerequirsites from builder 8Feb 20, 2014 11:37 am Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: ACTRON ESP+ Prerequirsites from builder 9Feb 20, 2014 12:23 pm Yeah I was thinking of single story, soz. Re: ACTRON ESP+ Prerequirsites from builder 10Feb 20, 2014 12:52 pm Guys can we consider post from 2007 still valid? If that is valid, I am probably in trouble, builder has taken out everything related to gas ducted heating not sure if they were going to provide any ducts downstairs or just on stair. They do not change if after contract. Any other options? Re: ACTRON ESP+ Prerequirsites from builder 12Feb 23, 2014 9:33 am Guys as this is not possible after handover, any thoughts on builder provided Braemer brand? Has anyone used or have any thoughts, views on Braemer 4 star heating with integrated cooling? Or Braemer Reverse cycle ducted cooling? Re: ACTRON ESP+ Prerequirsites from builder 14Feb 27, 2014 11:22 pm macmaz Guys as this is not possible after handover, any thoughts on builder provided Braemer brand? Has anyone used or have any thoughts, views on Braemer 4 star heating with integrated cooling? Or Braemer Reverse cycle ducted cooling? Its not impossible if you can have the builder install the ducts. I know for example Porter Davis will run ducts if you are adamant on installing heating/cooling post handover for example. You just need to ensure that the ducts can handle heating and cooling and that the 'design' of the ducts are correct i.e. they are laid out in accordance to the zoning plan that you intend to have. You'll then need to have an external powerpoint for the outdoor unit and you may also want to get the builder to run the copper pipe between where the outdoor and indoor unit will sit. It is admittedly a lot of 'prep' work, but its certainly not impossible Re: ACTRON ESP+ Prerequirsites from builder 15Feb 28, 2014 2:27 pm Serenity_Now macmaz Guys as this is not possible after handover, any thoughts on builder provided Braemer brand? Has anyone used or have any thoughts, views on Braemer 4 star heating with integrated cooling? Or Braemer Reverse cycle ducted cooling? Its not impossible if you can have the builder install the ducts. I know for example Porter Davis will run ducts if you are adamant on installing heating/cooling post handover for example. You just need to ensure that the ducts can handle heating and cooling and that the 'design' of the ducts are correct i.e. they are laid out in accordance to the zoning plan that you intend to have. You'll then need to have an external powerpoint for the outdoor unit and you may also want to get the builder to run the copper pipe between where the outdoor and indoor unit will sit. It is admittedly a lot of 'prep' work, but its certainly not impossible Still in talks with our builder. I asked them if there will be that option, seems like they have given me option to have ducts laid for add on cooling. Will that be same for reverse cycle do you think? On the sidelines has anyone heard of Livezy? Apparantly, they can provide Livezy reverse cycle airconditioning. Any thoughts? Third option they have given us is to go with breamer 4 star heating and lennaux add on cooling. Re: ACTRON ESP+ Prerequirsites from builder 16Feb 28, 2014 7:39 pm Livesy??? Doesn't even come up under a google search. Well I couldn't find it anyway. Why would you go with 2 different suppliers to supply the one item each when a number of suppliers do both. As said before we have Actron and no problems at all. Heating and cooling. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: ACTRON ESP+ Prerequirsites from builder 18Feb 28, 2014 8:40 pm delatite13 Livesy??? Doesn't even come up under a google search. Well I couldn't find it anyway. Why would you go with 2 different suppliers to supply the one item each when a number of suppliers do both. As said before we have Actron and no problems at all. Heating and cooling. http://www.livezi.com.au/ Sry Spelling mistake. Website looks amateurish. But The videos definitely look promising. Also ours is a double storey house 39sq and a bit of void, I feel zoning is very important. I thought this may be better achieved with Reverse Cycle zoning. Livezi seems to do zoning as well. Funny how they mention our competitors pointing competitors on their own site. Crazyk, as you mentioned earlier I am leaning towards Lennox option. But just thinking if reverse cycle with zoning may be more efficient. Just bear in mind this is http://www.urbanedgehomes.com.au/VIC/ka ... plans.aspx 4-39 double storey house in Melbourne. Re: ACTRON ESP+ Prerequirsites from builder 19Mar 03, 2014 12:07 pm I believe a dedicated unit will be more efficient than the add on. The other good thing about dedicated reverse cooling is that you will probably see higher air flow rates than the add on. The add on is also a compromise but still good. Re: ACTRON ESP+ Prerequirsites from builder 20Mar 03, 2014 12:58 pm Crazyk I believe a dedicated unit will be more efficient than the add on. The other good thing about dedicated reverse cooling is that you will probably see higher air flow rates than the add on. The add on is also a compromise but still good. This is only making my decision difficult . As for reverse cycle Livezi brand not much is found on the web and Lennox is good add on but you are saying reverse cycle is good in comparison. Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20413 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9565 |
