Browse Forums Heating, Cooling & Insulation 1 Jan 31, 2014 9:20 pm Hi I have recently had a 3.6kw Zodiac Pool Heater installed, and the specs stats Nominal Intensity of 16A and Max intensity of 22A. I have been advised that the cable available is 2.5mm, and that although there currently is a 20A breaker installed, this can be upgraded to 25A which the 2.5mm cable should support. Can anyone please advise if this is ok and if it is legal... are there any risks? Re: 25A breaker on 2.5mm cable - POOL HEATER 2Mar 16, 2014 9:59 pm wshaikh Hi I have recently had a 3.6kw Zodiac Pool Heater installed, and the specs stats Nominal Intensity of 16A and Max intensity of 22A. I have been advised that the cable available is 2.5mm, and that although there currently is a 20A breaker installed, this can be upgraded to 25A which the 2.5mm cable should support. Can anyone please advise if this is ok and if it is legal... are there any risks? It will depend upon the type of cable used, the length, how it is run to the heater (conduit, through roof insulation etc), the nature of the load etc. So the simple answer is it depends. Best to call in a sparky who can look at exactly what you have installed and advise the best and safest way to go. PS, just one question why do you think the breaker needs to be uprated? Is the 20A one installed tripping all the time? 0 671 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 7982 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 12294 |
