Browse Forums Heating, Cooling & Insulation 1 Jan 28, 2014 9:06 am Hi all,
I'm wondering if anybody knows of a bathroom heating lamp that you can get without the fan or lamps. I see IXL do a 2 lamp version without the fan but not a 4 lamp version. Of course, it needs to be good quality and made to last. Cheers. Re: BATHROOM HEATING LAMPS WITH NO FAN 2Jan 28, 2014 10:09 am For a while Mitre 10 had a plug in heat lamp that you could mount on the wall, which actually worked very well. I guess because you could mount it on the wall, you could mount it so much lower, therefore closer to people that allowed them to actually feel the heat from it. If you have high ceilings in the house, chances are is that they'll also be high in the bathroom as well. Pretty much all display homes I've been in have disabled the heat lamps in the bathrooms, so go to some open homes in your area, and see if you can feel any warmth from the lamps if the bathroom in them happens to have a high ceiling. I'm thinking of getting another one of them in our new house build, and using standard exhaust fans to take the steam out. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: BATHROOM HEATING LAMPS WITH NO FAN 3Jan 28, 2014 1:13 pm l built about 12 months ago with a small builder,l hired the electrician.l wanted two lamp heater he installed the four lamp ones,as l have ducted heating in bathroom/ensuite(l don't think lamps work very good and with high ceiling.IMO) l didn't want lamps for heat.Electrician wired only the two lamp for light,l wanted two fans.You could do opposite,disconect fan. Re: BATHROOM HEATING LAMPS WITH NO FAN 4Jan 28, 2014 1:30 pm Thanks guys. I found one in the end - Mercator have a single one that you can put into your ceiling. And I imagine it would be simple for an electrician to put two in and wire them to a single switch. Cheers. 2 4463 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 3669 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 3448 |
