Additional insulation on underside of roof - ?
house was built 2 years ago, we have a 2nd floor living space in the "ceiling space" (as it appears from outside) - and have access to the roof space around this.
There is insulation on the external sides of the internal walls in this space - but this area still gets ludicrously hot during summer.
I have installed 2 x solarstars (http://solatube.com.au/roof-ventilation/) and found they made no noticeable difference.
My next thought was to add another layer of insulation - on the "underside" of the roof. It is a colourbond roof, which has a lining of silver material on the underside already (called "sarking" I believe?).
So - to those in the know - would adding another layer of insulation at that location make any difference? and more to the point, does it pose any type of fire risk or contravene and building codes ?
thanks.
It wouldn't contravene any rules - just make sure if you have ceiling lights that you give a bit of space between the insulation and the light fitting for fire prevention.
Stewie
There is at least one Australian company that makes the insulated plasterboard, Kingspan. I haven't been able to convince my Australian builder to use it, so we may retrofit our 'colder' ceilings after handover.
Good luck with your project --adding insulation is a really good investment in energy savings and comfort.
Chris
I'd be curious to know what difference it makes
Stewie
as far as the other comment - I would be interested to see how well it works too! but would really prefer to do it once - hence the posting here.
I was thinking insulation batts + soundcheck gyprock.... but batts + foil board (depending on price) could be a good option.
3
Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too...
15/06/2023
Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like…
6/07/2023
2
1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it
