Browse Forums Heating, Cooling & Insulation Re: Installing air purification around the house 5Feb 21, 2014 3:01 pm shanevan I'm not sure what you are referring to. I wrote a blog about trying to reuse the air in the ceiling and discovered a company called Ventis that does it (see my blog at http://onsolution.com.au/blog/2012/ventis-fresh-air/). The system is relatively expensive (thousands of dollars) but you are getting the benefits of: - "free" heating top up in winter (this won't totally replace heaters, but will decrease the power bill) - "free" cooling during parts of the day in summer (especially late in the day) - fresh air at least once a day - reduced humidity in winter so less damp issues It's a great idea. I have since heard of similar systems. yes beneficial but quite pricey.. but having a stand alone air purifier for filtering air or a dehumidifier for reducing humidity is much cheaper i guess.. its up to the user what to prefer.. You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7030 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4670 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 |
