Browse Forums Heating, Cooling & Insulation 1 Nov 27, 2013 1:37 pm I've heard from a common friend who has ducted an air purification system installed all throughout her house. Since I can't talk to the person who had it, might as well ask it here. Is it expensive having that than a stand alone unit? is it advisable and more energy efficient? Re: Installing air purification around the house 2Dec 19, 2013 11:08 am I'm not sure what you are referring to. I wrote a blog about trying to reuse the air in the ceiling and discovered a company called Ventis that does it (see my blog at http://onsolution.com.au/blog/2012/ventis-fresh-air/). The system is relatively expensive (thousands of dollars) but you are getting the benefits of: - "free" heating top up in winter (this won't totally replace heaters, but will decrease the power bill) - "free" cooling during parts of the day in summer (especially late in the day) - fresh air at least once a day - reduced humidity in winter so less damp issues It's a great idea. I have since heard of similar systems. Re: Installing air purification around the house 4Dec 20, 2013 11:39 am shanevan I'm not sure what you are referring to. I wrote a blog about trying to reuse the air in the ceiling and discovered a company called Ventis that does it (see my blog at http://onsolution.com.au/blog/2012/ventis-fresh-air/). The system is relatively expensive (thousands of dollars) but you are getting the benefits of: - "free" heating top up in winter (this won't totally replace heaters, but will decrease the power bill) - "free" cooling during parts of the day in summer (especially late in the day) - fresh air at least once a day - reduced humidity in winter so less damp issues It's a great idea. I have since heard of similar systems. I think this is somewhat similar, my friend instead of buying an air purifier unit, she installed an air purification all around the house, i think its more expensive that's why i might as well choose to buy a unit for each of our room. I've searched for some products which are affordable enough like coway,honeywell,ionmax etc.. but i'll read your article also... sounds interesting! thanks! Re: Installing air purification around the house 5Feb 21, 2014 3:01 pm shanevan I'm not sure what you are referring to. I wrote a blog about trying to reuse the air in the ceiling and discovered a company called Ventis that does it (see my blog at http://onsolution.com.au/blog/2012/ventis-fresh-air/). The system is relatively expensive (thousands of dollars) but you are getting the benefits of: - "free" heating top up in winter (this won't totally replace heaters, but will decrease the power bill) - "free" cooling during parts of the day in summer (especially late in the day) - fresh air at least once a day - reduced humidity in winter so less damp issues It's a great idea. I have since heard of similar systems. yes beneficial but quite pricey.. but having a stand alone air purifier for filtering air or a dehumidifier for reducing humidity is much cheaper i guess.. its up to the user what to prefer.. Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4734 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6771 Ask yourself if the insurance company will be aware of the Reno. 4 7527 |
