Building ForumHeating, Cooling & Insulation
Phase change Insulation
Hi
I wonder if anyone has used a phase change Insulation. eg http://www.phasechange.com.au/casestudybiopcm
In discussion with my sister (physicist with phD) the physics of the material is sound, but not sure if the practical application is good?
TIA
quigly
I am familiar with the physics, having done it at school. It works.
The material data sheet on this one does not show the flammability, which I suspect is very high, as it seems to be a fat or oil substance inside the waffle - which is exactly what we did our experiments with at high school. And you can't use water to extinguish it. Excellent at storing and stabilising heat, but unfortunately not my idea of a safe product. (And very expensive for a wax/oil base @ around $36/kg of wax). The equivalent of filling your walls with kero...???
http://www.phasechange.com.au/Content/f ... %20Q25.pdf
SECTION 2 - COMPOSITION/INFORMATION ON INGREDIENTS
Ingredients and Components: Derivatives of Fatty Acids, Fatty Alcohols, Esters, Emulsifiers,
Thickening Agents and proprietary Cross linkers.
SECTION 5 - FIRE FIGHTING MEASURES
• Extinguishing media:
 SMALL FIRES: CO2 or dry chemical
 LARGE FIRES: Foam
• Unsuitable extinguishing media: Water spray may be ineffective on fire.
• Explosive limits in air:
 Upper: Not available
 Lower: Not available
• Special Protective Equipment: Wear self-contained breathing apparatus and full protective
clothing.
• Other Fire Fighting Considerations: Cool containers with flooding quantities of water until
well after fire is out.
SECTION 9 - PHYSICAL AND CHEMICAL PROPERTIES
[*]• General Information:
 Physical State at 25
o
C: Soft Gel
 Density: 0.8-0.9
 Appearance: Semi Transparent
 Odor: Neutral
 pH: Not applicable
Flammability (solid, gas): Not available
 Boiling point: >480° F (249° C)
 Oxidizing properties: Not available
Just ordinary "state" change as to solid liquid gas.
Different, but it sounds a bit risky for the material.
1
Frustration during Construction Phase
sorry wrong thread - deleted my post
18/09/2023
1
Home loan and landscaping change in price
Home Finance
Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes.
15/08/2023
5
How hard to change CDC plan for a brick veneer to double bri
depends on your council, some 1 day some 14 days
