Browse Forums Heating, Cooling & Insulation Re: Ceiling Fans........Which Brands 2Aug 27, 2013 6:46 pm Total Breeze Air Conditioning and Electrical - Based in Melbourne http://www.totalbreeze.com.au Re: Ceiling Fans........Which Brands 5Aug 28, 2013 6:51 pm Total Breeze Air Conditioning and Electrical - Based in Melbourne http://www.totalbreeze.com.au Re: Ceiling Fans........Which Brands 10Aug 31, 2013 7:09 am Total Breeze Air Conditioning and Electrical - Based in Melbourne http://www.totalbreeze.com.au Re: Ceiling Fans........Which Brands 14Oct 09, 2013 3:53 pm Total Breeze Air Conditioning and Electrical - Based in Melbourne http://www.totalbreeze.com.au Re: Ceiling Fans........Which Brands 20Sep 13, 2016 11:16 am Quote: Ceiling fans are wierd most of the brands you get are much of a muchness. I would more say the style determines the quality of it. Most of them come in 900mm and 1200mm thats the size of the blades. I would say the metal blade fans are better. they move the air heaps better then the timber ones and their heaps quicker to put together saving you on the install. If you get them from middys, ideal, Beacon their all pretty much same sort of quality. but to be honest im not a big fan of the martec ones bunnings are selling. In relation to the ceiling fans with lights your most likely best to get the light with a screw type blub fitting and putting CFL (fleuro type) screw globes in them. They draw a lot less power then then the best wordpress themes 2017, I not aware of any LED light fitting that fit into bathroom exhaust fan yet. Ask the salesman but I believe most fans have some sort of remote option you can buy you just wire them in. Thanks for your sharing, i will try that. Thank you fro your response, Simeon. It is good to hear that you have had a positive experience with Parisi. I am always on the lookout for reliable products, and personal… 2 4362 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7589 |
