Browse Forums Heating, Cooling & Insulation 1 Aug 25, 2013 9:43 am Hopefully someone can help ... could be a simple thing, but hey, what do I know about this!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the internal gas point for our gas heater. See this T-shape part on this bayonet installation, I mean the part which is screwed into the wall plate (or whatever that is!) and into which the hose connects into? The opening of that thingy (what is it called anyway??!!) currently faces the power point (as per the picture). We want to turn the opening around, so it faces the other direction, ie. away from the power point. Is this a DIY job, or do we have to call the gas plumber for this??? Is there any safety concern once we unscrew that thing from the wall plate? Not sure what to expect ... My signature is distracting people from my wise posts ... Re: Can anyone help with this?? 2Aug 25, 2013 12:51 pm Lex, You will need a gasfitter to do it, because he most likely just has to grab that elbow by hand and turn it clockwise!! If you are talking with the plumber that fitting is known as a gas bayonet. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Can anyone help with this?? 3Aug 25, 2013 5:55 pm Oh geez ... now I am not sure if you are teasing me or do I really need a trader Tell me clearly like to a 5 year old hahahah And preferrably, step by step please I can guess steps 1 and 2 ... 1) unplug the hose 2) unscrew those 2 little screws. But then what!??!? Call the gas plumber?! I am serious!! My signature is distracting people from my wise posts ... Re: Can anyone help with this?? Any gas plumbers out there? 4Aug 30, 2013 10:39 pm Oh well ... seems like this is one of those hard basket problems that nobody is really sure about ... just like me!! It looks simple enough, but is it really ... My signature is distracting people from my wise posts ... Re: Can anyone help with this?? Any gas plumbers out there? 5Sep 01, 2013 10:06 pm Lex, only a plumber can grab this thing and simply turn it clockwise. A plumber will also know that there are no little screws involved. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Can anyone help with this?? Any gas plumbers out there? 6Sep 05, 2013 4:50 pm Umhhhh, what do you mean? I can definitely see 2 screws ... one is even visible in the photo. This thing cannot be rotated without unscrewing it ... me thinks We probably would have tried it ourselves already but are unsure what is behind and if there are any safety issues, and if we should turn the gas off first ... My signature is distracting people from my wise posts ... Re: Can anyone help with this?? Any gas plumbers out there? 7Sep 20, 2013 11:39 pm Easydone 2 min job but get a plumber Fitzy Re: Can anyone help with this?? Any gas plumbers out there? 8Sep 22, 2013 10:20 pm Thanks (: So no escape from calling in the experts - again! even for something as small as this (: Looks like the gas for the house has to be turned off as well for safety reasons .. and something other than just "unscrew - turn around - screw back on" has to be done. My signature is distracting people from my wise posts ... Re: Can anyone help with this?? Any gas plumbers out there? 9Sep 23, 2013 1:20 pm pay gas fitter or risk killing your whole family to diy? call a gas fitter he will also do leak test to make sure its safe Hurry up and wait i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13151 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20456 |
