DIY Curtains, Pelmets and double thermal layers
Eg. Do we go a roman blind under a thermal fully lined curtain with a pelmet on top? Would a pull down blind be better? Two sets of curtains? What about a set of horizontal blinds (wood?) instead?
We're after thermal control, light control and minimal maintenance (two small boys = ruined special tracks or wrecked cords etc if we aren't careful).
I don't think any special lining is required, although I'll check with my architect who knows about thermal efficiency. From memory though, he was more concerned about pelmets than the type of fabric.
I've considered blinds but prefer the look of double-curtains. You can get some very thermally efficient blinds, but they're very expensive.
Your architect is right in that the pelmets stop the circulation of warm and cold air but the curtains should be considered too as part of the thermal equation.
Stewie
But what about here in Brisbane where we usually try to keep the heat OUT more than anything else?
Also if the curtains are floor length wouldn't that stop the circulating problem also?
Stewie
Doesn't hot air rise naturally? So why would it circulate through the curtain rail towards the window? I know cold air is denser and heavier so that drops etc...
Like EmyN says the warm air becomes colder so sinks but it also drags more warm air with it creating the draught. Once that motion of the warm air sinking then cooling starts it becomes a cycle.
The pelmets stop that effect ( or at least slows it down dramatically ).
It interrupts the airflow.
Stewie
have you used any of the motorised curtain systems available from Ebay? Which one and how is it?
9/08/2023
1
Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close…
