Browse Forums Heating, Cooling & Insulation 1 Aug 04, 2013 6:54 pm Hi all, I'm in the process of renovating my 1940's brick veneer house. And I'd like to install sarking and wall batts. How would I go about install sarking to an old house without taking all the bricks down? Plasterboard and electrical wiring has been completely removed already. Do I fit the batts, sarking then the plasterboard on top? As I wouldn't be able to slip the sarkingt behind the studs without removing all the brackets that hold the bricks to the studs. Thanks, Matt Re: How do I install sarking to an old house? 2Aug 07, 2013 9:22 am You won't be able to fit sarking to your walls in the usual way which as you allude to - on the cavity side of the timber frame. R 2.5 Batts between the timber studs then foil backed plasterboard would be your best option or batten the walls 25mm for an air space then breather foil ( R 1.5 ) and plasterboard. There are water repellant pump-in insulation products that fill the cavity. The manufacturers claim that is does not lead to moisture bridging the cavity either but I haven't used this type of product. What type of R-value are you trying to achieve for your outside walls ? Here is a link to the excellent Your Home tech manuals for a bit more info on this. http://www.yourhome.gov.au/technical/fs48.html Stewie Building Standards; Getting It Right! Hi all Iām in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 11713 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 |
