Browse Forums Heating, Cooling & Insulation Re: Air Conditioner Coin Operated Device 2Aug 04, 2013 10:22 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Air Conditioner Coin Operated Device 3Aug 04, 2013 3:33 pm Why not just make the tenants pay their own power bill? Re: Air Conditioner Coin Operated Device 6Aug 10, 2013 9:14 pm nsfw Hi I have a rental property in Perth WA and plan to put 4 split systems, one in each room, plan to rent each room separately. I want to know if there are any devices like coin operated or rfid tag based that I can connect to a split system unit so that when the tenant wants to use the aircon they pay first. Any ideas? Thanks a lot in advance. didn't you like the responses you received over on whirlpool about your boarding house...better luck here. Re: Air Conditioner Coin Operated Device 7Aug 27, 2013 7:07 pm Hi, I would look at the coin operated systems, If they have an option with a basic set of eletrical contacts them you can do it. Its acutally fairly simple but you won't find a specific air conditioner who will do it. I would go to the coin operated systems people and explain to them what you want to do. To be honest the cost savings you might make by making them coin operated might be less then if you just included it in the price. the coin operated units won't be cheap and then just a hassle to collect the money, plus people will see it as a negitive. especially if they run out of coins! Total Breeze Air Conditioning and Electrical - Based in Melbourne http://www.totalbreeze.com.au How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
