Browse Forums Heating, Cooling & Insulation 1 Aug 01, 2013 11:42 am Hi there, We are building an mcdonald jones bronte acreage style design with action air system ESP Plus. The house design is wide and has master bed down one 'wing' and home office next to common kitchen/living areas in centre then remaining 3 bedrooms and rumpus down other 'wing' end. Zone setup as follows: Zone 1: Master Bedroom & Home Office Zone 2: Home Theatre, Great Room, Meals & Kitchen Zone 3: Activities Room & Study/Library Zone 4: Beds 2, 3 & Guest Room Our actron air system only allows for 2 sensors so where best to place? The proposed setup currently is planned to give us one controller outside master bedroom with remote sensor in the master bedroom. Note return air vent in hallway near master bed. Would I be better off having the remote sensor down the other end of the house? Please help I understand actron is a very good system but I want to make sure we set it up best? Building McDonald Jones Bronte Manor One Contracts Signed Dec 12 DA Lodged Jan 13 DA Consent w/BAL40 Apr 13. S96 Consent w/BAL19 May 13. Slab Complete Jun 13. Frame Brick & Roof Complete Aug 13. Re: Advice Please - Placement of Sensors for Actron SRV203 E 2Aug 03, 2013 10:29 pm Hi Not sure if then sensors you're using are the averaging type but assuming they are, you'd be best to locate them in parts of the house that are going to be most frequently used. Being you already have one sensor in the the hallway close to the return air grille possibly zone 2 would be the optimal place to locate the other sensor but distanced from the kitchen as you don't need false temperature sensing from cooking heat. Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13724 Move your linen into laundry and access laundry from your present linen space 1 8007 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17603 |
