Browse Forums Heating, Cooling & Insulation Re: Ducted Air con wall vent 2Jul 11, 2013 6:44 pm Wanderer We have just moved into a house with ducted air conditioning with floor registers in each room. In the living room there is also a large wall vent approx 800mm x 500mm It is a white mesh type. I have just replaced the ugly metal floor registers in all rooms with gorgeous brushed nickel fancy ones and they look great! Now I want to replace the wall vent with something a bit more attractive but can't find anything online even remotely in the size I need. Any suggestions please? Cheers Wanderer It would help if you could say what you want? Bradflo has a big range of return air grilles, which is what you are talking about. If not exactly the right size, do remember it may be quite possible to go a little but larger. Click on the egg crate models below, and remember if what you buy is metal and you don't like the colour you can always get it powder coated elsewhere. http://www.bradflo.net/bradflo/au/grilles_louvres.htm How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5907 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
