Browse Forums Heating, Cooling & Insulation 1 Jul 08, 2013 6:34 pm does old insulation from the eaves have to be fully removed and new put it? getting earthwool batts put in the roof and installer/remover said they might not be able to get all the old insulation out of eaves since vacuum head can't fit it small gap she said it wouldn't make a major difference/influence in the insulation is this true? i'm guessing that air moves up and down only so the eaves are usually outside the home walls also, opinions on earthwool vs pink vs yellow batts? 2 7284 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6785 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8897 |
